HOW TO COPY OBJECTS BETWEEN LAYOUTS?
ChristopherVol
ChristopherVol
I am trying to copy objects from one layout to another, but can't.  I select the objects in one layout and chose either COPY or COPY WITH BAASE POINT from the Clipboard menu.  But when I go to the other layout PASTE is NO an option.
Trying to copy a Title Block and Legend, because they are different sized sheets.
ESchomberg
Is using wblock in one layout(select objects)
Then go to other layout and insert block not an option?
rl_jackson
Sometimes a simple restart will allow the information to be copy/pasted. I would ask does the legend/title block have annotative blocks contained in it, it could be copying but be invisible because the scale that is associated with the annotative items, is not getting applied to the copy, you might try turning on the auto-annotation feature (lighting bolt with scale in the lower right)
Rick Jackson
Survey CAD Technician VI
