how to connect the center line
Message 1 of 9
pls help to get all the data specially the center line of this drawing.thank you
Replies (8)
Message 2 of 9
troma
I don't understand the question.
What data do you need? How do you want to 'get' it?
Mark Green
Working on Civil 3D in Canada
Message 3 of 9
centerline station coordinate sir...thank you
Message 4 of 9
troma
What do you want to do with the centerline station coordinate?
Please elaborate on what it is that you are trying to achieve exactly; this will help people to understand what may help you and what won't.
Please explain what you have tried and why it didn't work. That helps people to make suggestions that are useful to you.
Mark Green
Message 5 of 9
Sir i want to get the alignment incremental report by using the report
manager in the toolbox. Every time i click the it says that no alignment
found. Thank you and sorry about my english grammar.
Message 6 of 9
Joe-Bouza
I can't open a dwg at this time. Are you saying the alignment is in the drawing and the report says it is not?
Please verify.
If there is an object please verify its type and properties
Joe Bouza
Message 7 of 9
There is  line that represent the centerline of the road,but if you click the incremental report in the toolbox says "No Alignment Found"..thank you
Message 8 of 9
Joe-Bouza
A line is not an alignment. You need to define it as an alignment through the ribbon or the prospector in order to get a report
Joe Bouza
Message 9 of 9
Joe-Bouza
Dude whT going on? Seems like you already accepted a solution to not having an alignment
http://forums.autodesk.com/t5/autocad-civil-3d-general/how-to-enable-the-alignment/td-p/6247033
Joe Bouza
