how to change the the the sign of offset when change the direction in section views!?
giscivil92
Message 1 of 15
giscivil92
Hi Everyone
I changed the direction in section views now I want to change the sign of offset for example for left side shows minus and right only value!?
Replies (14)
Message 2 of 15
cwr-pae
Use an expression and multiply the offset by -1.
Message 3 of 15
tcosta7B84R
Just to understand, when you say you changed the direction of your section views, what do you mean by that?
Technically, those offsets are related to your alignment, and the section views themselves cannot change the direction, but you can change the direction of your alignment; just be mindful that it can affect your design and all the elements connected to your alignment. If you still want to proceed, you change the direction of your alignment by clicking and going to your alignment tab, on the modify panel, click on reverse direction, and double-check your design before continuing work.
hope that helps
Message 4 of 15
tcosta7B84R
The expression would be for labels, not the bandset itself, and even though the data would be wrong since the sample line is correlated to the alignment, right?
Message 5 of 15
giscivil92
@tcosta7B84R Hi
I didn't want to reverse the alignment only I changed the direction of section views, so currently I want to change the sign of offset in data band in section views!
Message 6 of 15
giscivil92
I think this expression works for label, not for offset in data band!
Message 7 of 15
tcosta7B84R
How did you change the direction of your section views? Can you show here how did you do it? I am asking because as I said, your section view is a reflection of your sample line, and your sample line is correlated to your alignment, so what did you do to reverse the direction of your section view?
Message 8 of 15
giscivil92
@tcosta7B84R
Simply, You can go to section style in the tab graph you can change the direction
Message 9 of 15
tcosta7B84R
I see; yes, you are right; that should affect your band set as well. Are you applying it to multiple sections? Have you tried creating a new style out of the existing one and doing the same exercise?
Message 10 of 15
giscivil92
@tcosta7B84R
I just want to change the sign of offset in data band in section views. only this
if you know please guide me
Message 11 of 15
tcosta7B84R
I just asked if you tried to create a new style out of the existing one because it seems to be a bug on the process of using this style, it should change by itself when you run that reverse direction, if it is not changing, then try it with another style or close and open the file again.
Can you share your file here so I can have a look at it, if you don't mind, please?
Message 12 of 15
MMcCall402
Edit the band style to drop the sign for the distance values.
Then add the property for the Distance from Centerline Side.  This property will add R or L to the values based on the file settings for abreviations ... we can edit those setting to change R to - and L to +.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
Message 13 of 15
tcosta7B84R
That is a good solution, but that would only be a quick fix for one specific component, which is the offset itself, right? if you turn on the grid label, for example, it would be wrong, wouldn't it?
Message 14 of 15
giscivil92
@MMcCall402 Thank you for your guidance
currently, i have had a problem with negative values, how can i remove the minus sign !?
Message 15 of 15
MMcCall402
Use the first part of the process I posted earlier. The part where it uses the Drop Sign selection for the offset values. That will remove the minus signs from the band offset distance values.
Mark Mccall
CAD Mangler
