Hi @nkiakas, I think that so far, there are several things we can clarify:
1. You cannot change the "update mode" of a superimposed profile directly in the profile view where you superimposed it. You must change that behavior in the source profile, which leads us to clarification 2.
2. You can change the "update mode" for surface profiles and automatically-created offset profiles, not Layout Profiles. (see the following image)
Offset profile (you can change the update mode)
Surface profile (you can change the update mode)
Based on your example of Alignment A and Alignment B, in which both alignments have a profile view and a profile you are superimposing from A to B, I would say the following.
1. If the profile you created for Alignment A and later superimposed to Alignment B's profile view is a surface profile or an offset profile, do not try to change the "update mode" in Alignment B's profile view. This option will appear grayed as you showed in your screenshot. Instead, go to Alignment A's profile view, select the source profile, open the properties window, and change the "update mode" from dynamic to static.
2. If the profile you created for Alignment A and later superimposed to Alignment B's profile view is a layout profile, you won't be able to change the "update mode." You must rely on the "profile locking" options I mentioned in the second post.
I hope this helps. Best regards!
Camilo Fernández
P.Eng | Transportation
