Hi Syed,
Thanks for reaching out to the forum. In addition to Jeff's suggestion, I highly recommend checking out the tutorials below:
Tutorial: Creating a Cylindrical Manhole Structure - This tutorial covers the creation of a cylindrical-shaped storm drainage manhole structure. You can find it here.
Tutorial: Creating a Drop Inlet Manhole Structure - Learn how to create a drop inlet manhole structure using Part Builder. Follow the tutorial here.
Tutorial: Creating a Vault Structure - Interested in vault structures? This tutorial guides you through the process using Part Builder. Check it out here.
Following these tutorials should provide you with a solid understanding of how to design and model various parts for pipe networks. Happy learning!
Please let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
