How to change the reference point of Part Builder
ishaq03
ishaq03
Hi Everyone,
In the video that was recorded, I addressed my concern. Kindly watch the video. My concern, which is particular to the part builder, is that if the response is provided in a work flow format or a video is recorded, that would be very beneficial.
ishaq03
Update please.
Jeff_M
Have you tried this?
ishaq03
Hi @Jeff_M
I am thankful that you responded. Could you elaborate on how to replace the reference point of the original circle center point with the newly drawn circle center after using this command?
ishaq03
Any Update Please.
ishaq03
I'm still awaiting a response. Could someone please provide further details on this question?
lim.wendy
Hi Syed,
Thanks for reaching out to the forum. In addition to Jeff's suggestion, I highly recommend checking out the tutorials below:
Tutorial: Creating a Cylindrical Manhole Structure - This tutorial covers the creation of a cylindrical-shaped storm drainage manhole structure. You can find it here.
Tutorial: Creating a Drop Inlet Manhole Structure - Learn how to create a drop inlet manhole structure using Part Builder. Follow the tutorial here.
Tutorial: Creating a Vault Structure - Interested in vault structures? This tutorial guides you through the process using Part Builder. Check it out here.
Following these tutorials should provide you with a solid understanding of how to design and model various parts for pipe networks. Happy learning!
Please let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
