Civil 3D Forum
How to change border of Tin Surface
8 REPLIES 8
Message 1 of 9
ammTJB47
805 Views, 8 Replies
I have a surface in Civil that i made from the 3d lines that are in white in the picture. I used those points to create a Tin surface around them. Civil then automatically created a border around them (Yellow line). The border is not correct and does not follow the surface at all. I have tried to add boundaries in the surface prospector tab, but I keep getting error message (shown in picture).
Can anyone help me to get the right border around my surface?
Labels (1)
8 REPLIES 8
Message 2 of 9
Pointdump
in reply to: ammTJB47
Hi Alex,
"The border is not correct and does not follow the surface at all."
More details please. It would help if you could post your drawing. Have you tried using Maximum Triangle Length?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 3 of 9
ammTJB47
in reply to: Pointdump
I can post my Civil file.  no idea what triangle length is.
Message 4 of 9
Joe-Bouza
you have some options. In the surface build properties you can limit the length of triangles. this can be tricky but both understanding your data and or trial and error will get you better.
you can also draw a poly lint boundary to the determined limits and add as outer boundary
Joe Bouza
Message 5 of 9
ammTJB47
in reply to: Joe-Bouza
Polyline doesnt work, it still bugs out.
Message 6 of 9
Joe-Bouza
don't be so detailed you don't need arcs or gnats-a$$ it. a general pline that crosses the triangles you do not need.
super important: never collapse pline vertices on itself EVER
Joe Bouza
Message 7 of 9
ammTJB47
The surface the way it is, is how I need it to be. All the triangles aren't triangles they are polylines from the surface giving the surface its geometry and point elevations.  Without those lines I don't have a correct surface.
Message 8 of 9
neilyj666
@ammTJB47 the red polyline boundary is horrendous - self intersecting and with bulges etc.
I ran OVERKILL on it, converted to a 3D polyline, converted back to a 2D polyline and added as an outer boundary and it worked with no problems
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 9 of 9
brian.strandberg
Were I often see issues with new users on this is they connect the last point back to the start point of the polyline, then input C to close the line.  This duplicates the last point and will make it illegal for the surface boundary.
Thanks.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Rail Community
