Civil 3D Forum
How to calculate greatest length/distance within a closed polyline/polygon
5 REPLIES 5
dtroupQGUN6
447 Views, 5 Replies
dtroupQGUN6
Hello, I'm wanting to find a way to calculate the max or greatest distance within a closed polygon object and can't seem to find anything on the matter. The only method I can muster is to manually draw a circle starting at the geometric center of the object and find the 2 points at greatest distance that way.
Labels (2)
5 REPLIES 5
rl_jackson
in reply to: dtroupQGUN6
rl_jackson
Convert the object to a Parcel and the label will be placed at the centroid of the object. I'm not sure what your trying to do here, can you give a picture, or something.
Rick Jackson
Survey CAD Technician VI
Rick Jackson
dtroupQGUN6
in reply to: rl_jackson
dtroupQGUN6
Thanks for the reply. Attached is an example of what I'm looking at, I'm wanting a quick way to calculate the longest linear distance across a closed polyline object like the one attached. In this example I found it manually to be 30.9 meters.
rl_jackson
rl_jackson
I can't think of an easier way to do that without some sort of programming. Short of what you are doing right now.
Rick Jackson
Rick Jackson
pperales2
pperales2
Have you tried the inquiry tool? Please see attached image for refernece.
TerryDotson
TerryDotson
If you were to consider third party add-ons, DotSoft's C3DTools contains a Figure Extended Information tool that reports and labels extended info on a selection set of figures.  This includes the maximum distance between points like your image shows.
Rail Community
