- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am working on a project that has two coordinate systems. The first coordinate system is a WCS in the Southern Ohio State Plane (NAD83). The second coordinate system is a UCS that reassigns a known point to (10000, 10000) and a baseline that has a Northing of 10000. Additionally, this same known point is designated as the project base point such that grid & ground northings & eastings are equal. Attachment 01 shows the transformation I used to achieve this. Note that the X & Y positions shown in Attachment 01 are User-Defined Properties that were hard-keyed.
The issue I am running into is that when I jump between WCS & UCS, the Northings & Eastings of my COGO points are always in the WCS. I noticed that for regular points (non-COGO), there are X & Y position properties that do indeed update to reflect the selected coordinate system. Is there a way to add something similar to X & Y position properties for regular points to COGO points? See attachment 02 & 03 which shows the behavior of regular point properties when I jump from WCS to UCS. This is what I want to achieve with Cogo Points. I understand I can simply drop regular points on top of the Cogo points, but I'm trying to avoid this.
