I have created an alignment from an object (existing polyline) and developed a longsection which in effect is a route of a fire main pipe on a mining site.
The route now has to change and I need to add to the original alignment. How do I do this?
In the image below, the red line is the alignment (with chainage shown), the purple line is where the alignment now needs to route (around a compound on site).
Is there a way to add the points of the new purple line to the existing alignment so that it updates the longsection automatically?
Solved by v-silvestre. Go to Solution.
Solved by VincentSheehan. Go to Solution.
Edit the geometry and use the Alignment Layout Tools. Second button over from the left.
You can either select your alignment > right-click > Edit Alignment Geometry or from the Pull Down Menus > Alignments > Edit Alignment Geometry.
This will bring up the "Alignment Layout Tools" toolbar, from there just select the "Insert PI" button:
