I am customizing some properties via property set, however I want to add "drawing name" and other drawing properties a property in the property set?
Thanks in advance.
Haider
Solved by samir_rezk. Go to Solution.
You can insert an AutoCAD Field capturing the Drawing name as a Property set default!
Hope this helps,
Samir Rezk
Technical Support Specialist
