How to add assembly name?
Shevaniol95
Message 1 of 9
Shevaniol95
Hi all,
How to add assembly name like the pic attached
Note without using fields
I want it dynamic with assembly insertion
Thanks in advance
Ashraf E. Moures, F.E.
Highway Survey Engineer
LinkedIn | Facebook
Select Accept as Solution and click on Like
Replies (8)
Message 2 of 9
tcorey
Without using a Field? Also without AutoLISP? I could do it that way, but I still use Fields. To make the name insert when you add the assembly, what I do is copy a previous assembly and its name field.
I'm curious, why don't you want to use Fields?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 9
Shevaniol95
In the pic attached, there is no Field while inserting the assembly the name inserted dynamic
I'm curious, to know how
Thanks for your time Sir
LinkedIn | Facebook
Message 4 of 9
brian.strandberg
I'm not aware of a way to do that in the standard release package.  There may be something in a country kit, its hard to know everything in those unless you work with them.
Thanks.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Message 5 of 9
Joe-Bouza
I concur with @brian.strandberg  & @tcorey
Joe Bouza
Message 6 of 9
chriscowgill7373
it can be done, but it is going to take custom programming to get it done.  I would say that it might be difficult to find the program that was used, unless you talk to whom you received the drawing from.  Sincpac can do it, but it uses a field.  I wrote a Lisp routine that can do it, but I used a field.  I can't see the point of reinventing the wheel, when you can pull the info directly into a field so that it is dynamic.   Any other sort of programming would have to somehow link the text to the assembly, and if someone who doesn't have the program running changed the name, the text would not update.  By using a field, you don't need the program for the text to stay current.
In the image that was taken, the field background wasn't turned off, was it?
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
Message 7 of 9
tcorey
That's what I was going to ask. How does OP know that is not a field we're seeing? Maybe you can post your drawing?
Tim Corey
Redding, CA
Message 8 of 9
MMcCall402
I was just noticing that the intersection tool has a section to specify an assembly set to use for the intersection and will load that set of assemblies into the drawing.  In doing so it adds a name tag below each one that matches the name of the assembly.  The taga are just Mtext with no fields.  Its not dynamic but it does get created automatically when the assembly set is loaded.
The assembly set is stored as a single dwg file for each assembly and an XML file that organizes them in a 'set'.  Each dwg file is named the same as the the assembly within.  I imagine the name tags are coming from either the individual dwg files or from the XML.  (the name tags aren't in the dwg files)  But still, its not dynamic.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
Message 9 of 9
jessica.miller
It may be in the style display...?
Jessica Miller
Design Technician
CEC Corporation
4555 West Memorial Road, Oklahoma City, OK 73142
T: 405.753.4200
Dir: 405.753.4616
www.connectcec.com
