How to add a column to material table as item no.?
giscivil92
Message 1 of 14
giscivil92
Hi Everyone
How to add a column to material table as an item no. like this?
Replies (13)
Message 2 of 14
giscivil92
Unfortunately, I haven't found a way to solve this problem
I appreciate it if you could guide me.
Message 3 of 14
Joe-Bouza
Software short comings. I’ve not found anyway to add Payitem to a label/ table.
Joe Bouza
Message 4 of 14
giscivil92
@Joe-Bouza Hi
Do you think what's the solution if I don't want to modify the table manually!?
Message 5 of 14
Joe-Bouza
No I don’t. Maybe Project Explorer
can help, but I doubt it.
Best offer is to add the item number to the pay item description
Joe Bouza
Message 6 of 14
Joe-Bouza
Joe Bouza
Message 7 of 14
giscivil92
@Joe-Bouza
How can i do it may you show me the solution!?
Message 8 of 14
Joe-Bouza
I am assuming that you are using QTO. Are you? how are you getting the tables?
If using QTO, the csv file is in your system. Just edit the description column to include the pay item number
Joe Bouza
Message 9 of 14
giscivil92
@Joe-Bouza Hello
Really I didn't use QTO already.
I have just arranged the table with the material table.
I think the QTO is an interesting method could you please show with an example.
Message 10 of 14
Joe-Bouza
Explaining QTO in a post would be way to complicated. there are tutorials.
When you set up the material tables did you create the material names? same suggestion add the item number to the material descriptions
Joe Bouza
Message 11 of 14
giscivil92
@Joe-Bouza Hi
Thanks for your attention! I  can create the second and third columns with material however the material table doesn't accept "," "=" or like this I have to export to CAD and modify it,
So I welcome any solution that can help me to add the first column(Item No) to the material table.
anyway thanks
Message 12 of 14
Joe-Bouza
can you change the material descriptions
Joe Bouza
Message 13 of 14
giscivil92
@Joe-Bouza
Yes sure, but I would the Item No in a separate column!
Message 14 of 14
Joe-Bouza
Sometime we have to compromise. add the space in description and draw the line to separate
Joe Bouza
