How do I reference expression using label type line between 2 points
jeff.wangD95HG
jeff.wangD95HG
I have a line label that works perfectly for single line and poly line multiple segment. However it gives me ??? when I use the line between 2 points label type.
I am pretty sure it has to do with the label style reference expression that only exist in the line label style expressions and somehow it can't be referenced when using the label type line between 2 points
Solutions?
MMcCall402
Can you post a small dwg with it working in one instance and not in another?
Mark Mccall
CAD Mangler
VHB - Vanasse Hangen Brustlin, Inc.
Linkedin
jeff.wangD95HG
sure can
@MMcCall402
@Pointdump
it should work for you if you are not trying to reference expression in line label style. but if you are it will fail
Pointdump
Hi Jeff,
Line between 2 points label style is working OK for me. Are you saying it doesn't work when you try to rope in an expression? As Mark says, please post a drawing.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Pointdump
Jeff,
Thanks for posting your drawing.
Have you tried changing the format to "Dimension" or "Distance"?
Dave
Dave Stoll
Las Vegas, Nevada
jeff.wangD95HG
just tried it still ???
i would think if that is the problem then I wouldn't even be able to label it on a line
MMcCall402
It appears that no expression value will work in a Point to Point label.
Mark Mccall
CAD Mangler
Linkedin
