How do I add a Tangent Intersection Label to an alignment??
In Civil3D there's a label type called "Tangent Intersection Lable" for alignments.
It appears in the settings section of the prospector, and it can be asigned styles.
But I fail to find the way how to add such a label to my alignment.
It seems that there's no command and no associated menu item to do this.
Where did I miss something???
erdemcelenk
You could find that label you are talking about by using the Annotate tab.
Annotate--Add Labels-- Alignment -- Point of Intersection
Then you must select the alignment you'd like to label, that's it.
Erdem Çelenk
Civil Engineer,MSc.
Thank you for your quick reply, but I'm refering to a different label.
Please distinguish between the
Point Of Intersection Label
and the
Tangent Intersection Label.
They have a different range of information they have access to.
Both label types appear in the settings section of the prospector, but only
the Point Of Intersection Label is available on the Annotate tab, as you
mentioned.
I know that the Tangent Intersection Label exists, I've seen it in a
drawing, but I can't figure out how to add one.
Jeff_M
@Anonymous, @erdemcelenk is correct. You can assign 2 types of styles to this label type. Depending on which one is currently the default will determine which one is used.
Thank you SO MUCH!
