How can I deselect linework from a current selection set, based on color, line type, linestyle etc.., is this possible?
pbradburyYWE5N
Message 1 of 20
pbradburyYWE5N
If I have a selection set of a variety of different linework is there anyway to "deselect" certain linework based on color, line type, linestyle and etc..? I'm looking for something that doesn't require me to hold down shift and deselect the hundreds of features I want to deselect.. Is this really not an option? In the example image below, how do I simply deselect the circle but keep the line selected?
Replies (19)
Message 2 of 20
MMcCall402
Once they're all selected, right click on the screen and choose "Quick Select" from the menu.  That will bring up a menu where you can add or remove items from that selection set based on properties of those items.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
Message 3 of 20
pbradburyYWE5N
Thank you but this doesn't work. I've tried this and when I choose "exclude" from a current selection it simply deselects everything I have selected. What am I doing wrong here? I am trying to exclude an "object type" from the selection set, that doesn't appear to be an option in quick select?
Message 4 of 20
Joe-Bouza
share the drawing
Joe Bouza
Message 5 of 20
pbradburyYWE5N
Its any drawing, I just started a blank drawing with absolutely nothing in it except a single line and a single circle and when I select both of them, all I want to do is simply deselect the circle and leave the line selected. The formatting of the circle and line are exactly the same, same color, level, linetype, linetype scale, plot style, lineweight, transparency, hyperlink, etc... Can I not just simply deselect certain objects from a selection set? What the heck is the purpose of having this drop down in the properties dialogue if I can see the properties of just the line vs just the circle if I then can't do anything with it? So dang frustrating, just trying to get such a simple thing like this to work.. I wanted to mention that unlike the simplified example below, I have thousands of such features that I want to deselect, so holding down shift and clicking on each of them is a horrible waste of time..
Message 6 of 20
Joe-Bouza
I do not see that we can deselect via qselect.
that  being said it looks like the selection set(s) need to be built in phases
Joe Bouza
Message 7 of 20
AllenJessup
What I usually do is use QSelect to prepare a selection set of what I'm going to want removed. Then I do the massive selection and use R(emove) P(revious).
Allen Jessup
CAD Manager - Designer
Message 8 of 20
Joe-Bouza
more examples
Joe Bouza
Message 9 of 20
Joe-Bouza
can you show a sample? im not seeing where the R, P options happens
Joe Bouza
Message 10 of 20
AllenJessup
@Joe-Bouza
Joe,
I think I'm getting what you're showing. Does that work if "Apply to" is Current Selection instead of Entire Drawing?
Allen Jessup
Message 11 of 20
AllenJessup
I created a Selection set of a few of the polyline then selected them all
Then on the command line:
Command: SE
SELECT
Select objects: Specify opposite corner: 7 found
Select objects: r
Remove objects: p
4 found, 4 removed, 3 total
I could have used QSelect or any other method to create the first Selection Set. You just need to build one of the entities you want to remove after selecting a larger set.
Allen Jessup
Message 12 of 20
pbradburyYWE5N
Ok, I figured it out. If you use the QSELECT first and select objects of a certain type and then filter it based on the other properties that does what I wanted to do. It accomplishes the end goal but it is horribly un-intuitive, your first selection option HAS to be the object type and not ANY of the other properties you want to filter for, because you can't filter an object type on top of something else.
Message 13 of 20
AllenJessup
If you want to dive down a rabbit hole. Check out the Filter Command. You can build an and/or type of filter.
Allen Jessup
Message 14 of 20
pbradburyYWE5N
Yeah I saw the filter feature but that definitely felt like bringing a gun to a knife fight, way overkill for the simple single selection I wanted to make..
Message 15 of 20
Joe-Bouza
SE is the missing puzzle piece
Joe Bouza
Message 16 of 20
AllenJessup
R and P works almost any time you're asked to make a selection. I think it doesn't work with some Civil commands.
I just used Select instead of Move, Rotate, Erase, etc. Since I didn't want to affect the entities.
Allen Jessup
Message 17 of 20
AllenJessup
@pbradburyYWE5N
Yeah. Not a command you'd use if you don't have to. It is useful when trying to build a complicated selection and has the advantage in being able to save the Filter.
Also, it doesn't work with Civil 3D objects.
Allen Jessup
Message 18 of 20
Joe-Bouza
I was working exclusively with QSELECT and didn't see anything on the command line option
Joe Bouza
Message 19 of 20
AllenJessup
Figured. But I wanted to add that to add that for those who come after.
Allen Jessup
Message 20 of 20
pbradburyYWE5N
I wish Autodesk could emulate how this typically works in Microstation, hopefully this is a change that comes to Autodesk products in the future. See below how it is done in Microstation, your Element Selection tool which is used to select anything. You can easily add to and remove linework from a selection set via the various tabs in this tool, so much easier than the Autocad equivalent. There are many things in Autocad that work better than in Microstation but this definitely isn't one of them 😞
pbradburyYWE5N_0-1703178138778.pngpbradburyYWE5N_1-1703178162959.pngpbradburyYWE5N_2-1703178188067.png
