- Hi there, could you tell me how to make this Invert Design? I cannot get it from the labels composers , cheers
if this profile is the profile view with the data band, then you need to create a profile that for invert design.
The quetion is āHowā, this is the profile view. I need to create this band.
in the profile view properties, then go to Bands tab, then select Band type what you want (it should be Profile Data) then Select band style that for your invert design , then click Add button, then you will see your data band in this profile view
Sorry, I think it should be in the band type: pipe.
if you choose band type is Pipe data, then please understand for the pipe data about invert, you can chose only start/end Invert elevation on the properties, that maybe not get invert elevation at every station what do want. it up to you. but if you just drawing the profile that following your pipe along profile view then you can labeling invert at every station what you want.
