Civil 3d 2025 - Where is the button to Export an Autodesk Civil 3D Drawing to an AutoCAD DWG File ?
andre.micka
andre.micka
I often use the command EXPORTC3DDRAWING but it seems the button disapeared in C3D 2025 in the menu export.
So can someone tell me where it is hidden ?
Thank you
nkiakas
Hi @andre.micka
File-->export-->export to AutoCAD-->choose the DWG/DXF version you need
Alternative type (_AecExportToAutoCAD2010) in the command line (without brackets)
I hope it will help you
ChicagoLooper
Hi @andre.micka
There are multiple ways, here are some of them:
  1. Click Output tab=>Export panel=>Export Civil 3D Drawing. OR
  2. On the command line, type EXPORTC3DDRAWING. OR
  3. On the command line, type ETRANSMIT. (In File Format dropdown, select the AutoCAD 2018 Drawing Format with Exploded AEC objects option.) OR
  4. On the command line, type EXPORTTOAUTOCAD. (Before doing ExportToAutoCad, download then install C3D Object Enabler for your version.)
Chicagolooper
andre.micka
Thank you,
the number one is the solution without enter the command.
It is strange that Autodesk has deleted the icon in the file ribbon export.
