Hello All,
I'm trying to model underground electric cables using custom subassemblies. I've created two subassemblies
(See Assemblies.png), one for direct buried cables and the other for a concrete ductbank for the cables to run through when they pass under roads.
The way I do it is by creating separate feature lines for the direct buried cables and ductbank then building corridors from them (a single feature line with different corridor regions is also an option). This creates corridors with the cables running straight into the ductbank which is not what I want. (See Corridor 1.png)
As the direct buried cables approach the ductbank by say 5 meters, they should transition from 1 row to 2 rows then pass through duct bank column by column starting with the far left column. (See Corridor 2.png)
The opposite should also happen when the cables leave the ductbank.
Does anybody have any idea on how to do this?
