The archtick doesnt's display the diagonal line, only it's outline, but in the block editor it looks okay.
I purged it from the drawing and tried to copy a dimension with the same style from a new drawing (where it displays well) but it shows the same "empty" block.
Any idea how can i fix this?
Solved by pendean. Go to Solution.
Hi Szuri,
Try FILLMODE = 1.
Dave
Dave Stoll
Las Vegas, Nevada
It was set to 1.
The object thats inside the block is a simple line and not a hatch object. That's why it's strange for me that it shows as it has some kind of outline, but in fact the line's global width is set to a default number.
But now I checked it, all the lines and ploylines that I set a global width does the same thing.
