hey all
I create points work 2 hour and more but forget to save I lost my work,
can I find these created points in database
not found in tem folder and not in bak file
regards
Solved by tcorey. Go to Solution.
If you have controlled,
Drawing Recovery Manager or
C:\Users\UserName\AppData\Local\Temp and .bak file path,
I think there is no way to find.
If you lose the drawing, you lose the points, unless:
1. You use Autodesk Vault for project management
or
2. You use Survey Database
or
3. You export the points to an ASCII file to use as a backup.
