Civil 3D Forum
Welcome to Autodeskโ€™s Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D topics.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Help??
3 REPLIES 3
987 Views, 3 Replies
Help??
how do i get rid of those two extra slope lines at the corner when grading a pad with square corner or when grading a feature line that has many vertices with segments deflects different directions?? I end up having lots extra lines at each vertex.....  how do I extract Batter Ticks from a corridor? -  lot of times, i need extract just 3d poly lines and batter ticks. but i dont know how to extract batter ticks apart from exploding the entity. is there better way?....
cheeers ๐Ÿ™‚
3 REPLIES 3
Attach a PNG or JPG shot of what you are talking about vis-a-vis "two extra slope lines." Also, what are "batter ticks"? Another pic might be needed.
Hi there i have attched few attachments. first attchments is the "batter ticks" that i m talking about. they are actually slope lines or tadpoles in a form of lines. Second attachment is grading and see attached, there's two extra lines at each corners and vertices. how do i get rid of them?? Third attachments is a Corridor. the objective is to extract only 3d poly lines and slope lines or tadpoles to form a 3d drawing. How do i extrac those tadpoles from a corridor and how do i turn off the X-sections line if desire to?? ๐Ÿ™‚ what is the quickest or better way to achieve this other than explode the whole entity and delete out what i dont want. it's very time consuming
many thanks
perpetualjon
I know this is old but did you ever find a solution to this?
Rail Community
