- Mute
- Permalink
- Report
I have been with working with Map on Civil 3D 2020 on a Windows 7 Pro device to edit data on a PostgreSQL service. Until recently, I have been able to successfully connect to our database, add the data to Civil 3D, and edit data. In the last few days, when I use the Map service, I run into an issue in which I cannot add data from my PostgreSQL database to Civil 3D. I am able to connect to the database without issue, and the service successfully logs in and shows all of my schemas. However, after I check-mark a schema and click "Add to Map," nothing happens. I receive no warnings, and the service does not crash, it just un-check-marks my selected schema and nothing happens.
Any help would be greatly appreciated.
