How do I “mail merge” data from excel into my sheets so that the following happens.
In excel
Column A of the spreadsheet would be title
column B would be data relating to that title
Column c (as b etc)
in civil, how do I link the spreadsheet
then:
when the title is selected in the field of sheet/title block, field 2 below reflects the relevant cell of that row but column b and so on and so forth
can you then generate a sheet for each row/entry in the spreadsheet automatically like the mail merge function in word?
Solved by SoaresASBCAD. Go to Solution.
Not sure how @SoaresASBCAD @solves your wm question. A very good reference to fields.
I would go with SSM for title block info. I do not know if an OOTB way to go from excel to SSM, but @@JTB world has a SSet creator that uses an excel file. I’m not a sales rep, just a satisfied customer
Joe Bouza
