Help with creation of volume boundaries
- Mute
- Permalink
- Report
I'm exporting a geological model (which would be a boundary of a volumetric unit) and trying to generate the surface of that model on Civi3D. The boundary is represented by 3D faces.
Steps taken:
1 - open the file on Civ3D (.dxf file, also tried with landxml (.xml))
2 - create a surface
3 - go on the definition, drawing objects. select object type as  3D faces and select the entire model. After the generated surface is done, I use the alignment tools to generate a profile view, but the surface is kinda spiky because we have different volumes (the geological unit is not single unit, but different boundaries of the same material) it generates only one surface, not the boundary.
Is there a way to generate the boundary of that volumetric unit, what we would expect would be as below:
Where rather than the profile view "bouncing" from each node of the top and bottom we rather see a true slice.
See the attached file to play with!
