Help With Assembly
Help With Assembly
coffey9ZJZP
Help With Assembly
coffey9ZJZP
I am trying to create an assembly according to the attached cross section. I need the slope to come down at 2:1, intersect the existing ground surface and create a ditch. I'm having trouble selecting the right sub assemblies.  Thanks
tcorey
You could use a LinkSlopetoSurface for the initial fill line, then a LinkWidthandSlope to cut down to the ditch bottom, and, lastly, another LinkSlopetoSurface for the cut slope out of the ditch.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Jowennl
Hi coffey9ZJZP,
I agree with Tim above and just want to add that you can also use conditional cut and fill subassembly to help you with more conditions. See attached screencast as a guide.
Cheers,
Jowenn
imran_tamrahi
Jowennl thanks a lot for your kind reply
i worked on your suggestions that was great but i have a problem my shoulder sub assembly is in different slope in cut and fill reaches in fill 2:1 and in cut 1:1 and ditch
i am searching the method in which automatically my shoulder sub assembly apply in 2:1 in fill reach and 1:1 in cut reach.
and sir what about benching in cut reaches if i use conditional  fill in need benching in cut reaches.
regards
