Help Subassembly Composer
bgalleze
bgalleze
Hello Everybody,
I want adding the stripping for the pkt attached, if you want help me.
Thank you.
Accepted solutions (3)
cyberflow
Hi @bgalleze
You'll have to use the "Surface link" component in SAC
Before adding that you'll need to create a few things :
Add a starting point
Add a target surface (For targeting the surface you'll want to strip)
Add a Offset target to target the offset of the stripping
Add Input parameter for the width of the stripping if your not using any targets
Add Input parameter for the depth of the stripping if you want to control the depth of it
I've attached an example
You can go to on the Autodesk site to download the sample of PKT they have
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Sample-PKT-files-f...
There you can open their examples and learn a lot from there !
Good luck !
P.S. I noticed that .PKT files can't be attached on the forum, they need to be zipped so that they can be attached.
Frank Freitas
CAE/CAD/BIM Coordinator & Support Specialist
LinkedIn
bgalleze
Thanks for your reply,
Please can you make it on my file attached. thickness=30cm
thank you
cyberflow
Well thats the thing you havent attached a file
And you'll need to put some effort there to try at least with the guidance i've provided ...
By the way when attaching a pkt, you need to zip the file and attach the zip file
Frank Freitas
LinkedIn
bgalleze
Thank you for your replay.
cyberflow
My pleasure
Dont forget to accept my answer has the solution
Have a great day
Frank Freitas
LinkedIn
