HELLO ALL
IS THERE AN OPTION TO GIVE TO CIVIL THAT IF I PUT ON GROUND ABOVE EXISTING GROUND THAT THE PRORGRAM SHOULD FIRST EXTRACT 40 CM' FROM EXISTING @ ONLY THEN PUT ADDITIONAL NEEDED LAYERS?AND THE SUM OF ADDITIONAL WOULD BE ALL AND NOT ONLY ABOVE/ AND ITS NEEDED ONLY IN AREAS OF ADDITION
HELLO ALL
