Help file for ANZ RMS Pram Ramp Subassembly
dinesh.parajuliH4C5F
Message 1 of 9
HI All,
Where can i find the help file or document for the RMS Pram Ramp subassebly from ANZ RMS Country kit 2023.
Many Thanks.
Replies (8)
Message 2 of 9
Elina.P
Autodesk Support
Autodesk Support
Hi @dinesh.parajuliH4C5F!
In general, you can access the CK Help file from the software level by accessing the subassembly properties:
But I am also attaching the ANZ Country Kit documentation for Civil 3D 2023.
Please take a look and let me know if that is something you were looking for!
Elina P.
Technical Support Specialist
Civil Engineering Solutions
Message 3 of 9
dineshparajuliH4C5F_0-1677623632541.pngThank you very much. Any help with associated with above.
Cheers
Message 4 of 9
m_kingdon
I actually can't find the help file associated with this subassembly either.  Both in 2022 and 2023.  Maybe it has been removed?
Mike Kingdon
Civil 3D Zealot
Message 5 of 9
bikash_shah
@dinesh.parajuliH4C5F  did you get any solution for it. Please let me know as i am too looking for it.
Message 6 of 9
Naser_abdpour
I am also looking for one
Message 7 of 9
rizikhan7780
Community Visitor
Community Visitor
For information on the ANZ RMS Pram Ramp Subassembly in the ANZ RMS Country Kit 2023, refer to the official documentation provided by ANZ RMS. You can find the help file or document on the ANZ RMS website or contact their support for assistance in accessing the relevant documentation.
Message 8 of 9
hi
I rather used the corridor transition tool to create the curb let down and created the cutdown. Hope this helps for you as well.
Thanks 🙏
Message 9 of 9
james7_mary00
Community Visitor
Community Visitor
Unfortunately, the help file for the RMS Pram Ramp subassembly in the 2023 ANZ RMS Country kit isn't readily available online. However, you can try searching the Autodesk Community forum, contacting ANZ RMS directly, looking for user-created guides, exploring the Country Kit itself, and utilizing alternative sources on pram ramp subassemblies in Civil 3D. Don't give up, and hopefully, you'll find the information you need!
