Hello, I am unsure if this is possible from messing with the styles and research i have done, but I am trying to add a transparent mask or border around my spot elevation labels. I have been able to create a mask surrounding the elevations by adding a text component to the bottom of the styles draw order and using blank spaces to set the width and height, but I need to be able to see underneath it. I also removed the mask, and turned on the border viability, but I also need border to be filled in.
The first screenshot is what I have created so far, the second is a screenshot of what I am trying to accomplish but within Agtek 4d, and the rest are settings of what I have used. I am open to all suggestions and lisp routines if possible. I am using Civil 3D 2020, thank you.
