Hi all,
I am calculating the volume of soil using method Average Volume Calculation, but I see that the result table has a problem. Almost all the positions are correct, only 2 positions of the filled soil have the wrong volume calculated ?
I have checked and exported the material table again but the result is still the same.
Can someone help me with this problem ?
Solved by nguyenlehoang.cj. Go to Solution.
Try to add frequency lines on corridor at the problematic locations.
WATCH THIS to get a better idea
I still haven't figured out the cause, has anyone ever had this problem, can you help me? 😓
I searched and read some articles about this problem.
==>The solution: uncheck a box for curve tolerance. And the result is the calculation will be correct as when calculated manually.
