HELP - Adding a feature line to a surface/corridor
I am very new to Civil 3D; and I have to work on a project that was started by another person with whom I am  no longer in touch.
She created a surface, alignment, profile, cross sections, etc... The cross sections have a label that shows where the property line is, and the property line is a "feature line".
I would like to do the same for the other side where there is another property. I drew a polyline where I want the other surface line to be, then I converted it to a feature, and chose the option to match the surface elevations. Now I would like to add this feature line as a "breakline" on the existing cross sections, and whenever I choose the "add to surface as breakline" option and go through the prompts I get an error saying "error adding breakline"
How do I add the label of the feature line to my cross sections?
Thanks!
samir_rezk
Hi @Anonymous
You don’t want to add the feature line as a breakline! This command is to add the feature line to surface object to define terrain elevations.
there is several methods for getting the property lines to show on a section view; the easiest method is to select your feature line and go to the home ribbon tab/find the drop down menu under sections and choose project on section view. The next dialog box will help you assign a label.
hope this help,
Samir Rezk
Technical Support Specialist
Topmig
Hi @Anonymous ,
You can try this:
1-Copy the feature line to the same place
2-Explode de copyed feature line (It will become a 3DPoly)
3-Add that 3DPoly as a breakline.
Hope it help's.
wfberry
Why?
Bill
Topmig
HI @wfberry ,
My response was based on the question:
"Now I would like to add this feature line as a "breakline" on the existing cross sections, and whenever I choose the "add to surface as breakline" option and go through the prompts I get an error saying "error adding breakline"
Is there anything wrong with it?
I'm always learning!
wfberry
OK, he was informed in the previous post that adding a breakline was not the way to do what he wanted.
Adding a breakline is done to change a surface elevations but the the breakline in question was derived from that surface, thus no change.
Bill
Yes! This is what I wanted to do, THANK YOU!
