Is there way to add riverwall to hecras? I want to print hecras cross section with riverwall on each side.
quickest might be to code in a "levee" at station elevation under RAS geometry editor.
I'm not sure what exactly HEC RAS is, but I just found a button in C3D 2015 under Output > Export > Export to HEC RAS., and remembered seeing this Q.
Hope that helps.
Hope that helps.
