Civil 3D Forum
HEC-RAS 2D Geotiff Errors
6 REPLIES 6
Autoslave2019
354 Views, 6 Replies
Autoslave2019
Any idea why I would be getting these errors when trying to add a C3D Geotiff?
6 REPLIES 6
fcernst
in reply to: Autoslave2019
fcernst
6.0 and higher doesn’t like C3D’s GEOTIFF offering.
One workaround is to bring it in using 5.07 then move on to 6.2.
Dotsoft can create compatible tif and flt files..
Fred Ernst, PE
C3D 2025
Ernst Engineering
www.ernstengineering.com
Fred Ernst, PE
C3D 2025
Ernst Engineering
Autoslave2019
in reply to: fcernst
Autoslave2019
That worked! Thanks!
That would never had occurred to me, so easy once you know the solution.
Autoslave2019
Autoslave2019
Any chance you could point me in the correct direction on why I can't see the RAS Mapper added Boundary in the Unsteady Flow viewer?
I need it to show up to then add precipitation values to run rain on grid...
This is a C3D forum, I'm still looking for a HEC RAS 2D forum on the web, nothing yet..
fcernst
fcernst
Rain on grid is distributed evenly over the 2D flow area ..you probably haven’t defined a 2D flow area yet
Fred Ernst, PE
C3D 2025
Ernst Engineering
Fred Ernst, PE
C3D 2025
Ernst Engineering
fcernst
fcernst
Just looked at your screenshot.. so you do have a 2D flow area for that geometry
You need to associate your Unsteady Flow with a Geometry... Right click on Geometry in RAS Mapper and Manage Geometry Associations…..
Fred Ernst, PE
C3D 2025
Ernst Engineering
Fred Ernst, PE
C3D 2025
Ernst Engineering
Autoslave2019
Autoslave2019
Thanks for your response, much appreciated!
Rail Community
