i upgraded to c3d2020 recently and started using the ribbon more. for some reason hatching has become an issue. i used to be able to pick the hatch button and a window would pop up with all the options. now when i pick the ribbon it automatically assumes i'm selecting an internal point. of course the drawing hangs up because it's selecting everything in the drawing. how do i get the window to pop up like before?
Solved by samir_rezk. Go to Solution.
Take a look at this very recent thread! how to turn Hatch command Pop-up window on
Samir Rezk
Technical Support Specialist
thank you!
@nostupidquestions - Wouldn't it be nice if there was a "classic" workspace/profile that would leave existing commands working the way they were in the past?
I just don't see what benefit there is in changing things like this for existing users. If we want to TRY it, fine. But don't change the default behavior @autodesk
