Hatch Pattern
Hatch Pattern
sanetdikkumbura1950
Message 1 of 8
Hatch Pattern
sanetdikkumbura1950
I want hatch my pipe network this hatch pattern. where can I find this hatch pattern?
Replies (7)
Message 2 of 8
ianjchap
Hi @sanetdikkumbura1950,
Thats probably a linetype rather than a hatch.
Change your centerline line type to dashed, then in the plan tab tick the 'specify width' and the linetype will extend to the outer line of the pipe width.
Ian Chapman
If you found this post useful, please Like the post.
If this post helped you successfully solve your problem, then click on the ACCEPT SOLUTION button.
Message 3 of 8
sanetdikkumbura1950
Thank you for the reply. I was hoping for a hatch pattern (solid and spaces).
Message 4 of 8
mjung
Our pipe style utilizes a custom hatch pattern to mimic what you have shown in your example.
It's just a simple pattern definition that has been added to our ACAD.pat file:
*SDPIPE, Pipe Hatch
0, 0,0, 0,.05, .85,-.75
Civil 3D 2026 / Windows 11 Pro (64bit)
Intel Core I7 @3.30GHz / 32gig RAM / NVIDIA Quadro K2200
Message 5 of 8
ianjchap
Hi @mjung,
Is this a Custom pattern? How would I insert this into a style?
Ian Chapman
Message 6 of 8
mjung
Hi Ian,
Yes, it is a custom pattern that would need to be added to the acad.pat file or configure CAD to find a custom one.
Once the hatch is available configure your Pipe Style as shown in this image.
Message 7 of 8
ianjchap
Is the Hatch Pattern created by you, or available somwhere?
Ian Chapman
Message 8 of 8
mjung
You will need to open your Acad.pat file with a text editor and insert the following code:
*SDPIPE, Pipe Hatch
Or create a text file called sdpipe.pat with the code above and load it.
This article has more info: How to install custom hatch patterns in AutoCAD
