MMcall is on the right track, you need to use a user defined contour, which
is found on the analysis, not to be confused with a contour analysis, you
will need to make sure your style is setup to show user defined contours.
Nick
wrote in message news:5547233@discussion.autodesk.com...
i need to keep my contour intervals at 1 for minor and 5 for major. I only
want to add the 1 contour, which is 126.5. if i use the surface analysis i
have to change my minor contour interval to .5, i dont want to show all of
the .5 interval.
