Civil 3D Forum
GSB file does not show up in library
4 REPLIES 4
hhj308685
402 Views, 4 Replies
I want to create a custom project-specific CRS (in Snakegrid, HS2TN15_NTv2). To accomplish this I have a GSB file that I would like to place in the right location in the Autocad Civil 3D folder structure.
My approach was the following:
  1. paste the GSB file in the following folder under this path:
    C:\ProgramData\Autodesk\Geospatial Coordinate Systems 14.08
    The first obstacle was that there are four different folders where only the number 14.0x changes. Which one should I choose?
    I assume that the right one is the 14.08 one since Civil 3D is the last program that I installed on my machine.
    Then inside the 14.08 folder, I created a sub-folder that I called 'Snakegrid'. In the 'Snakegrid' sub-folder I pasted the GSB file that I also called 'Snakegrid'.
  2. In the command line in Autocad Civil 3D I used the command 'MapCSlibrary'.
  3. There I searched for the 'Snakegrid' GSB file, but nothing showed up.
Am I doing everything right so far in the process? And did I place the GSB file in the right location?
Thank you so much in advance for your help!
Caroline
4 REPLIES 4
Pointdump
in reply to: hhj308685
Hi Caroline,
I think:
14.00 = 2014
14.04 = 2018
14.08 = 2022
"Then inside the 14.08 folder, I created a sub-folder that I called 'Snakegrid'. In the 'Snakegrid' sub-folder I pasted the GSB file that I also called 'Snakegrid'."
So far so good, but you're not there yet.
A GSB file basically says, if you're in this square, shift X this much and Y this much. A GSB is denser(smaller squares) in populated areas for greater accuracy.
The big question is, shifting what to what? A GSB file handles Geodetic Transformations between Datums, like between NAD83 and CSRS, Canada's version of NAD83.
So find out more about what Datum you're transforming.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
hhj308685
in reply to: Pointdump
Thank you for your comment Dave!
The conversion should be from OSGB1936 to Snakegrid. The issue is that the GSB file does not even show up when I look for it in the library inside AutoCAD. So I also can't set the CRS that it should convert the file from.
Pointdump
Caroline,
You need to create both a custom Coordinate System and a custom Geodetic Transformation. The custom Coordinate System is necessary because you'll be using a different Datum. Can you post the GSB and maybe a drawing in SnakeGrid Coords? Forum will accept pretty much anything if you Zip things together.
Dave
Dave Stoll
Las Vegas, Nevada
Pointdump
Caroline,
Further reading >>>Here<<<.
Dave
Dave Stoll
Las Vegas, Nevada
Rail Community
