I'm running both C3D 2018 and 2019. C3D locks up when I try to turn hardware accelerator off or on. It will lock up through the options command and graphicsconfig command.
Is there any other options to turn off/on hardware accelerator?
Solved by AllenJessup. Go to Solution.
START AUTOCAD WITH THE COMMAND LINE SWITCH /nohardware
SEE
You might want to see if the Graphic Card Drivers need to be updated.
You can find a list of Icon Switches here:
Allen Jessup
CAD Manager - Designer
Try -graphicsconfig (note the hyphen). See if it will work from the command line.
Allen Jessup
Could the dialog be coming up offscreen?
Hello @Anonymous ,
Just checking to see if your problem has been solved. Did the response from our experts above help answer your question? If yes, please click on the "Accept as Solution" button in his reply so this helps other users in the community find the solution too. Thanks!
