Civil 3D Forum
Grading
2 REPLIES 2
ryleyFEQWE
486 Views, 2 Replies
Grading
First of all, i am very new to C3D other than some experience at school 3-4 years ago.
I attached two files, one of the drawing i'm currently working on and another (JPG) of a finished site i am basically trying to recreate/copy. (i do not have the original drawing for the JPG)
I am trying to copy the drainage design while learn the most i can from this for future jobs.
I'm trying to add drainage swales to the front and back of the trailers (running south), as well as in between them. I assume the trailer pads will most likely have to be raised above eg.
Trailer pads are to be flat
I'm trying to have a minimum slope of 2-3%.
Shooting for a 150mm - 200mm elev. drop from trailer pad foundation to the nearest swale to reduce flooding risks.
I need a 4m distance between trailer and top of embankment around furthest south trailer to allow future access behind the units (i believe i have done this)
Like i said i am very new to this, as it is a big learning step and making me very frustrated. I have tried adding feature lines for the swales but i am having a hard time.
any info on how i can make this easier would be very much appreciated.
2 REPLIES 2
@ryleyFEQWE ,
What a great looking project! Thanks for bringing this to the community, while we can't comment on the engineering or design I can at least point you in the direction of how to add grading objects via some online help documentation and maybe a video to help you get moving to your end goals.
Grading Workflow
Refer to this section for high-level descriptions of the most common grading tasks you might perform when working with grading in AutoCAD Civil 3D.
Copper Chadwick
Designated Support Specialist
@ryleyFEQWE ,
I am checking with you to see if my post helped answer your question? Please hit the Accept as Solution button if a post fully solves the issue or answers the question.​ Thank you for your participation, your accepting a solution adds value to the post for the community as a whole, and helps other members find answers to their issues.
Copper Chadwick
Rail Community
