When I create a grading I get those rund edges
I wonder if that is possiable to make that rund edges for corridors too?
Please see the pic!
Solved by Jowennl. Go to Solution.
Hi @Anonymous ,
Just add tiny fillet radius curve in your alignment corner. Then you will have the same effect as grading. Also, make frequency smaller for the curve to make it smoother.
Cheers,
Jowenn
Jowenn Lua | Retired Account See My New Profile Here
AU 2023 CES600726 – Getting Started with Generative Design in Civil 3D: A Beginner’s Guide
AU 2020 CES473668 – Supercharge Your Dynamo Graph with Civil 3D Toolkit
AU 2019 CES319333 – Dynamo in Civil 3D Introduction Unlocking the mystery of scripting
AU 2018 CI225967 – Using Automation in Civil 3D for Construction Documentation and Exports
AU 2017 CI123653 – AutoCAD Civil 3D and Subassembly Composer— Real-World-Practice Tips and Tricks
