Grading with Feature lines
- Mute
- Permalink
- Report
I am looking for any tips or suggestions when grading with feature lines. I am regrading a large, several hundred acre, mine site for reclamation. I am breaking my surfaces up by phase, so a single surface does not become too large or complicated.
Currently C3D is hanging when trying to perform an infill. When I execute the infill I get the green diamond and then C3D just chugs away and nothing happens. Ever. I end task. audit. purge. recover. audit purge. No help.
The area I'm trying to infill is large. 40acres (not sure because C3D is current stuck again) The boundary of the infill is made up of several different feature lines that connect to make a enclosed area. I wasn't sure if that method would work, but I tried it on a smaller area and had good success. I was even able to grade to surface at 3:1 in the smaller area. But for some reason C3D is on a long break from productivity.
Any thoughts or steps that you like when grading large areas?
PS. How long do you let C3D hammer away before you END TASK?
Thank you!
