Announcements
Grading with existing contours as feature lines
Does anybody know how to grade with existing contours as feature lines. I made them all feature lines and added them to a surface but still am having trouble getting it to grade.  The dwg is linked if anyone has any ideas.
Udo_Huebner
My first hint: NEVER freeze layer 0
My second hint: Use a Civil template like "_Autodesk Civil 3D (Metric) NCS.dwt" currently your AutoCAD Units are in "Feet" and Civil Units are in "Meter"
Gruß Udo Hübner (CAD-Huebner)
Pointdump
Hi Abigail,
Normally Feature Lines are added to a Surface as Breaklines and Polylines are added as Contours.
I used Command -DWGUNITS ("no" to scale objects in drawing) to change your Metric drawing to Feet and UNITS to change to US Survey Feet. Then your horizontal linework lines up pretty good with Bing Live Maps. But your Surface remains in Meters. I don't know what to do about that.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Joe-Bouza
What does getting it to grade mean?
i see @Udo_Huebner  & @Pointdump  commented on you drawing units, but we should get clear that traditionally we grade to EG as a target. If you are trying to modify eg to what you want a finish grade to be you’ll want to consider changing direction
target eg with grading tools and create FG surface. You can make a separate composite surface and paste EG&FG together if you desire a single end product- graded
Joe Bouza
