I have a large site with daylight grading objects most of the way around the perimeter. The perimeter grading uses just one feature line. The daylight slopes vary and I've successfully used grading transitions between the regions of varying slopes. There is one location where I'd like to use a grading object to mimic a small retaining wall. So I've done the following;
1) Grade at 3:1 to elevation 106.
2) Grade at 0.1:1 to a relative elevation of -6
3) Grade to a distance of 12 feet at a slope of -2%
4) Grade at 2.5:1 to daylight.
My question is, can I use a grading transition to link the bread pieces of this grading sandwich to the set of grading objects described above? (see attached screen shot)
