Civil 3D Forum
Grading Transition With Grade To Distance
8 REPLIES 8
Message 1 of 9
holmino
1009 Views, 8 Replies
Good morning,
Is it possible to use the grading transition to grade to distance at different lengths? Please check the .jpg for clarity. Thanks for your help, Enrico.
8 REPLIES 8
Message 2 of 9
fcernst
in reply to: holmino
Yes it is...
Fred Ernst, PE
C3D 2025
Ernst Engineering
www.ernstengineering.com
Message 3 of 9
holmino
in reply to: fcernst
Fred,
Thanks for your quick reply. Could you list the steps you took to get it done when you have time?
When I try transitioning, the grading equals out on all sides. I should note that I'm not grading to the existing ground surface. Just a 2% grade from the foundation at the different lengths as mentioned. I'm going to try again. I will post the file with my results. -Enrico
Message 4 of 9
holmino
I've got one side to work, but it looks funky. When I try transitioning on the other side, the entire grading becomes one piece. For my transition, I'm clicking in between the gradings, not using points as I don't know how to use that. I've attached the file. -Enrico
Message 5 of 9
fcernst
I just quickly converted a rectangle to a featureline, then created the for partial Distance criteria gradings for each side, then created the transitions.
Fred Ernst, PE
C3D 2025
Ernst Engineering
Message 6 of 9
holmino
Got it. I will try it like that and report right back. -Enrico
Message 7 of 9
fcernst
You just need to give a little more room around the corners so it can create the Transitions.
Fred Ernst, PE
C3D 2025
Ernst Engineering
Message 8 of 9
holmino
I got it to work. I graded the 4 sides first like you said, then added the transitions by clicking in between the gradings. I clicked closer to the outer edge and it worked fine. Thank you very much for the help and quick response. -Enrico
Message 9 of 9
holmino
...and I left more room as well, like you mention.
Rail Community
