Grading Tool Settings
jwylie2020
jwylie2020
Is there a setting for the tessellation (triangles) interval on a surface made from grading tools to be changed?
I am grading from a featureline and the resultant surface is making triangles at 10' along the featureline.
I am trying to reduce the data generated to see if the grading will be more stable.
I know, I usually use corridors but this was started by someone else.🙄
JL
Civil 3D 2020
JL
C3D 2024
Win 11 Pro
jwylie2020
Of course I just found it right after my post.
Grading Group Properties.
Automatic surface Creation
Tessellation Spacing
Thank you self.
JL
C3D 2024
Win 11 Pro
Joe-Bouza
Happens to me all the time
Joe Bouza
Joe-Bouza
Tell us where so someone with a similar problem can get help.
then you can select your own solution accepted or I can do it for you
A screen grab would be excellent
Joe Bouza
