When using the pathway tool on a curb ramp at a radius. The ramp needs max cross slope of 2% and max travel way slope of 8.3%. If you use the short side of the ramp as the pathway you have a triangle left out and if you use the long side of the ramp for the pathway, you overshoot the radius.
How to work this?
Hi @clbears3510, it's not ideal, but I think I would use the short side and then draw a closed polyline for a zone in the missing triangle. The way it's drawn it will impact the slopes in the road, but if you pull it back you'll still want a constraint on the missing triangle like you said. You may just need the extra zone, like I show in blue. It's possible an Offset Points line like I show in red may be needed to constrain a max elevation difference to meet the max 8.3% slope. If you then turn Aligned Surface on for the zone I think you'll get I triangle maintaining the cross slope along the adjacent edge of the pathway, and the max longitudinal slope along the other edge.
Thanks, will give that a shot. I thought messing with priorities might work but hadn't got there.
Below is a similar problem that I believe will require an additional zone, non-uniform sidewalk width.
