Grading objects and aligning
apdim
apdim
Hey,
I'd created bridge model in Revit and im trying to import it on my civil alignment and grade the terrain around it.
1. How can I transfer it to Civil 3D to exact position? I'd read about Civil Connection or using Project Basepoint but I cant find exact way to do it.
2. How can I grade surface around it? Grading for me is working only with lines, arc, feature lines but not with 3D models. I've created topo around it in Revit, but I want to transfer model only and grade it in Civil.
3. If everything is completly ready in civil, how can I transfer it to InfraWorks? It transfers only surface and alignments, object is missing.
I've tried many ways from YT videos but I still cant manage how to do it(its for uni project, but I still want to do it right in 3D). Thanks!
Accepted solutions (3)
RonaldBrañez
HI @apdim
watch this video, I hope it helps you
Regards.
rl_jackson
You'll probably need to download the Shared Reference Point utility for Revit and C3D
Rick Jackson
Survey CAD Technician VI
apdim
Thanks, It works for 1. Creating alignment->creating region and assembly for structure->corridor export with coordinates->creating structure in Revit by alignment with same coordinates and then importing back in Civil.
But I still cant find way to grade this object. I want this part(marked in yellow) to be solid infill and then after the wall to start 1:1.5 grading.
How can I transfer everything to Infraworks? Alignment and surfaces are trannsfered but structure is missing.
rl_jackson
To transfer data to Infrawork from C3D there's a Tab specifically for that Infraworks, I'm not familiar with Revit enough to get you there but I'm sure the Revit forum can help.
Rick Jackson
RonaldBrañez
You can do it as shown at 6:10 (with corridors) placing the alignment at the position outside the wall, or you can create a feature line and generate the grading.
