Grading Object passes through surface in batter.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi All,
I'm trying to grade to an existing batter. I want to calculate volumes for various stages of the backfill. I have set up a feature line to hug the structure that will be built and created a grading at 0% (flat) to target the surface of the existing excavation (batter). On the straight areas it is behaving as expected (green), however when it changes direction, it producing and arc which is going slightly past the batters (circled red), so I end up with some cut volumes which I should not have.
How can I fix this, is there a way to make it generate the true daylight / intersection line with the batter all the way around?
