When modifying a feature line elevations the grading elevation editor (panorama) doesn't hold the cell location. See pics below. I changed elevation of the feature line at station 1+20.79 and panorama defaults to the bottom of the list which makes it difficult to keep track of where I am when modifying the feature line. Is there a setting a change or another way to modify vertices to avoid this?
Solved by user181. Go to Solution.
Hi @Anonymous You could try using the quick elevation editor on the ribbon. Select a feature line and look on the ribbon in the edit elevations panel. After selecting quick elevation edit hover over the vertices and lines to see elevations and slopes then left click on one to change the value
I agree that this is behavior is a usability issue that should be addressed.
This has already been posed in teh Ideas section, and was "Accepted" in October of 2016.
You can still vote it up.Elevation-Editor-Feature-Line
Christopher Stevens
